hi all hope some one can help i need to replace the u jonts but dont no what part nu or best place to order them from i have the alloy propshaft dont know if that makes a difference
You can get the u-joints from any parts supplier(Advance/O'Reilleys.Carquest,NAPA,AutoZone etc).You need to specify that you have the aluminum driveshaft.The u-joints are different for it from the steel shaft.Also the aluminum's front u-joint and rear u-joint carry different part numbers.I bought mine from Advance front P/N 1-0626BF and rear P/N 3-3130.
