steering box leak- confused as to what's leaking-
Old Sep 11, 2015 | 08:38 PM
bubbaz28's Avatar
Car: 1983 Z-28
Engine: 305 LG4
Transmission: 5-speed
I have finally determined where my leak is coming from... the steering box, by the rag joint... I have done a bit of searching here, (I see the sttering box rebuild sticky and it helps) but I am confused by the many parts at the end of the steering box! Do I replace the rag joint and seals at the end of the box? The box entirely? Sorry I really am trying to figure this out by searching the forum- didn't know steering was so freegin complicated!
Thanks, Bub
Attached Thumbnails steering box leak- confused as to what's leaking--steerleak.jpg
Old Sep 11, 2015 | 08:42 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: steering box leak- confused as to what's leaking-
I would opt for a rebuilt box rather than rebuild myself, you do not have to do the rag joint but since it has to come out when you do the box I would.
Old Sep 11, 2015 | 09:16 PM
bubbaz28's Avatar
Car: 1983 Z-28
Engine: 305 LG4
Rag joint seems cheap enough, especially if I have to replace the box.
Old Sep 11, 2015 | 09:31 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
http://www.summitracing.com/parts/aa...model/firebird
Old Sep 12, 2015 | 01:22 AM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Just FYI, rag joint is indeed cheap, but is a pain in the @$$ to replace. You have to grind or drill the rivets out and replace them with bolts, and getting the rivets out is not fun. If you have the proper tools it probably wouldn't be too bad.
Old Sep 12, 2015 | 09:11 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
a front seal kit can be had to fix that without taking the whole box apart.
oil kills rag joints. time to replace that anyway.
Old Sep 12, 2015 | 10:30 AM
skinny z's Avatar
For what it's, my rebuilt/reman steering has a leak in the spot you've described. It was leaking from day one and it took me forever to figure that out.
The solution (for me) was a can of Lucas Power Steering stop leak. It's working so far.
Old Sep 12, 2015 | 11:41 AM
bubbaz28's Avatar
Car: 1983 Z-28
Engine: 305 LG4
Yea, the grinding/ drilling rivets out deal seems like a pain. Maybe I can avoid it...
Old Sep 12, 2015 | 11:43 AM
bubbaz28's Avatar
Car: 1983 Z-28
Engine: 305 LG4
I might try this first! Thanks!
Old Sep 12, 2015 | 11:48 AM
bubbaz28's Avatar
Car: 1983 Z-28
Engine: 305 LG4
An input shaft seal kit? This one?
GATES 351310 {#2774, 2968, 35131} Power Steering Repair Kit; Stg. Gear Input Shaft Seal Kit
W/Ring Retained Housing
Thanks!
Old Sep 18, 2015 | 02:09 PM
naf's Avatar
naf
do a search for the jeep shaft to replace the rag joint completely. happy with mine.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Jorlain
Oct 8, 2015 01:57 AM
SG91camaro
Sep 5, 2015 10:27 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
