TRANSGO 2nd gear servo spring/spacer install help
Subscribe
May 20, 2007 | 03:19 PM
I am installing the JR shift kit.The 2nd gear accumulator calls for a spcer, blue and orange spring. The factory has a little sleeve that goes over the rod where the piston slides over. If I put the spacer supplied in the kit, with the shorter blue spring, and this little 1/2 sleeve the piston will not go down all the way to where it will fit like it was when I pulled it out. Now I can see it will fit with force etc when bolting it up, but is this correct.
Getting pics soon.
I am holding the sleeve that was in with the original piston spring combo. If I put the spacer in, with that sleeve the piston wont go down into the body without FORCE.
Reply 0
Subscribe
