Will a fourth gen trans am rear end fit on my 82?
Old May 21, 2007 | 11:47 PM
badass82's Avatar
Car: 82 camaro berlinetta
Axle/Gears: 2:73
My friend has an 95 trans am that just changed from 2.73 to 3.42 rearend. Will his old rear end fit under my 82 camaro. Will it need to be modified?
I read through some of the other posts, it seems that it will bolt in but the e-brake cable is too short. How would i go about fixing this problem? Any other problems with the brakes?
Old May 22, 2007 | 12:20 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: Will a fourth gen trans am rear end fit on my 82?
the only big difference would be that the 4th gen rear end is slightly wider (2" i believe) than the 3rd gen rear. So the tires are going to be sticking out a bit more.
Old May 22, 2007 | 12:32 AM
badass82's Avatar
Axle/Gears: 2:73
cool. The only thing that im worried about is the brake lines for the disc rear end. I had drums on the back before.
Old May 22, 2007 | 12:48 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
you will want the proportioning valve for a disc/disc car. riggin up the lines shouldnt be too bad as long as you have an autoparts store nearby.
Old May 22, 2007 | 12:55 AM
badass82's Avatar
Axle/Gears: 2:73
how much would the proportioning valve cost??
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 6, 2015 09:03 AM
