I need a Shift Kit!
Old May 22, 2007 | 11:57 PM
SAMRS350's Avatar
Car: 1989 Camaro RS
Engine: TBI 350 - Approx 300hp
Transmission: 700R4 (Soon to be Built)
Axle/Gears: 3.73's & Eaton Posi
I need a Shift Kit!
I have an 89 RS with a 300Hp 350 and and Eaton Posi and 3.73's. I make great power and have told myself for a long time i need a shift kit to fix my lame shifts. I am aware the Trans-Go kit is the best, but is also Very Complicated to install.I am not comfortable installing this kit and dont want to pay a shop to put it in. I have interest in the B&M Transpack, and The Trans-Go Jr. Kit. The Trans-Go Jr. Kit i am realy in the fog about, I dont know much of it's functions, is it easy to install? lots of Parts? Help?? Cany anyone recommend something with good Results?
Old May 23, 2007 | 04:36 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: I need a Shift Kit!
transgo is the best. don't waste money on anything else. the transgo jr. kits addresses a lot of the problems with these transmissions but doesn't do anything to to really tune the transmission. the full transgo kit isn't that difficult if you have any mechanical aptitude. look up dana on this board. he goes by Pro Built Automatics. he has a kit that combines the jr. andthe full version plus has the vette servo i think. his instructions are also more detailed from what i understand.
Old May 23, 2007 | 08:51 AM
SAMRS350's Avatar
Car: 1989 Camaro RS
thanks!
Old May 23, 2007 | 11:41 AM
Pro Built Automatics's Avatar
Are you looking for the Performance setup? or a Heavy Duty kit? The HD is much simpler to install, but will not let you hold 1st gear to any rpm. If you let it shift on its own (leaving it in overdrive), then the HD kit will do just about what you want. I add the Corvette servo to the HD kit along with the larger boost valves. Let me know if I can be of help?
Old May 30, 2007 | 09:58 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
How much is that HD kit? What about manual/automatic shifting?
Old May 31, 2007 | 12:08 AM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Im interested in this as well. Just found out tranny didnt have a shift kit. Any chance of getting the kit with a billet servo?
I think I found it. Correct me if Im wrong.
http://www.700r4l60e.com/store/produ...&cat=28&page=1
How bad is this to install? I dont mind changing the servo or pulling it apart a little.
http://www.700r4l60e.com/store/produ...8&bestseller=Y
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
