Question about an 87 camaro rear differential
Old May 26, 2007 | 09:15 PM
chopped31's Avatar
I have an 87 Camaro rear diff. that I am using on my hotrod. My question is, on the top of the rear just as the housing transitions into the axle, there is a small hole that is not threaded. Looking down into it I can see the axle. Is there a plug of some sort that goes into this hole? I know something has to fill it, just want to know what the hole is for and any suggestions of what to put in it.
Old May 26, 2007 | 09:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Question about an 87 camaro rear differential
its on the right side? its a vent, there is a plastic vent fitting that goes there.
Old May 26, 2007 | 09:26 PM
chopped31's Avatar
Yeah, right side top near the axle bearings I believe. Is this a parts house type item or more likely a dealer part? Does it have a check valve in the line or just a straight line to the outside? Thanks for the help.
Old May 27, 2007 | 12:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you should be able to get it from a dealership, if not classicindustries # G6028 $3.95
should be a 7/16 hole
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
