Dont need GM posi additive, if you are running syinthidic?
Old May 27, 2007 | 01:41 PM
Parts4sale's Avatar
can i just run a syinthidic lube 75 - 90, i have a limted slip diff, "i heard i dont need the GM Posi Additive" if im running syinthidic lube?
Old May 27, 2007 | 01:45 PM
zot_man's Avatar
Re: Dont need GM posi additive, if you are running syinthidic?
buy royal purple line of limited slip gear oil.The "synthetic" blend you refer to will work just fine as long as it specifies on the bottle it is for limited slip use
Old May 27, 2007 | 02:06 PM
Parts4sale's Avatar
i have mobile 1 syinthidic (75w90) i bought 2 bottels
Old May 27, 2007 | 02:09 PM
1989formula355's Avatar
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
if it says "limited slip additive" or something to that effect on the bottle then you're all set. i know royal purple synthetic is safe.
Old May 27, 2007 | 02:30 PM
Parts4sale's Avatar
i looked on the bottels and it said for conventional and limted slip use
how much do i put in?
Old May 27, 2007 | 03:12 PM
fill it til it trickles out the fill hole
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
