The Ultimate Shift Kit For 700r4 -
Old Jun 5, 2007 | 04:02 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
I have purchased and installed a shift kit that made my automatic a stick shift. No more TV adjustment. No more automatic up shifting and downshifting. Every gear is manually shifted. I can start off in OD if I wanted (no reason why). This is the shift kit I always wanted. TRANSGO reprogramming kit #700-2&3 "Stick Shift Option."
This sounds like an advertisement. I'm just finally happy that something I bought really made a difference.
If you do this kit, read all of the directions before you even touch your car. Some things are tricky.
Also try to purchase and install a corvette shift-servo. And don't overfill the tranny like I did and get black flagged from the drag strip for leaking oil.
1988 Camaro Sport Coupe: Orignally: 305 TBI 700r4
Now: 1974 355CI, 2bolt, Badger Flat Head Pistons w/ valve relief, Melling high performance street cam, GM Cast Vortec Heads, Edelbrock RPM Air Gap Intake, Holley 650, GM HEI w/ vacuum advance, Accell Super Coil, K&N, Holley Fuel Pressure Regulator, Flo-Tech Heads, Motronic Underdrive Pulleys, 3.73 Posi, 700r4 w/Corvette Shift Servo, Transgo Stick Shift Kit, 16" IROC Wheels Best Times:1/4 mile 13.87 @ 97.25
Old Jun 7, 2007 | 09:47 AM
Shagwell's Avatar
Car: projects.......
Re: The Ultimate Shift Kit For 700r4 -
It's called a manual valvebody and has been around for years. The downside is they are not very street oriented and can lead to the death of a trans if not operated properly, especially those that eliminate the tv cable, thus running max pressure all the time.
It should also be said that the vette servo is ok, but a billet would be much better for a hi-po application.
Old Jun 7, 2007 | 07:08 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
My TV adjustment is exactly where I left it, before I did the kit. At least now I never have to fool with it.
This kit is amazing. It honestly shifts like a manual. No waiting for the gear to apply. Very positive shifts.
And very consistant.
As far as everyday use..I would run it.
Old Jun 21, 2007 | 06:15 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
But some should not run it...but I would
Old Jun 21, 2007 | 07:57 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
FYI, the transgo kit includes a vett servo, so no need to purchase one seperately.
Old Jun 21, 2007 | 08:53 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
Not the kit I purchased. There was a paper advertising the servo in the box.
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
