Tv cable slack?
Old Jun 6, 2007 | 06:30 AM
Keepin This One's Avatar
Car: 1988 iroc/2000 saab 9-5
Engine: 355 tpi/Roller cam
Transmission: 700r4/2800 stall,megashifter
Axle/Gears: 3;42
Tv cable slack?
Just wondering, How much slack should i have at the throttle linkage, with a correctly adjusted cable?
Should the tv cable be tight?or only tight at wot?
Also at what part throttle should the cable be opening the throttle valve?
Thankx in advance, sean.
Old Jun 6, 2007 | 06:40 AM
Re: Tv cable slack?
http://www.tvmadeez.com/
Old Jun 7, 2007 | 07:47 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Tv cable slack?
Tight always.
Old Jun 7, 2007 | 08:59 AM
Shagwell's Avatar
Car: projects.......
Re: Tv cable slack?
It should be fully extended at WOT, tight always. If it's fully extended at WOT, but not tight at other times or not shifting correctly at part throttle, look into the sonnax tv correction kit.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
