Transmission Going?
Old Jun 26, 2007 | 08:51 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Transmission Going?
I recently purchased 1987 Camaro (base style) that originally had a 2.8 L engine, but was replaced with a 5.7 L out of an 87 IROC by the previous owner. I am assuming that they also switched the transmission from the v6.
My problem is that when I put it in drive/reverse, it takes about to seconds to catch the gear. My first guess is that it needs to be rebuilt. Could it be that the bands are just lose? It shifts nicely when its going down the road. Let me know what you think. Thanks
Old Jun 30, 2007 | 08:42 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: Transmission Going?
Anybody have a theory on this?
Old Jun 30, 2007 | 12:53 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
there is only one band in the 700r4 and you can't adjust it without taking the servo out and replacing/modifying the apply pin. check the level and condition of the fluid. it just might be a little bit low. if the fluid is discolored it may be dirty and need to be changed along with the filter.
Old Jul 1, 2007 | 12:38 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I checked out the fluid and it looks like it was just replaced, good level and color. I had a look underneath the car and saw that the tranny is missing the front cover. It is also leaking some fluid and I believe it is just because of a few lose bolts. Any theories on something else it could be? I'll have a closer look for anything out of the ordinary.
Old Jul 1, 2007 | 09:30 AM
87zjeff's Avatar
would still still replace the filter. most anything else gets fairly complicated for the home mechanic.
Old Jul 2, 2007 | 08:09 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Ok, I'll replace all the fluid and all that goes with that and see how it works
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
