vibrations above 70 mph
Old Jul 3, 2007 | 10:08 AM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
I tried searching for this problem and didn't come up with anything. Driving one day, I heard clanking noise from under the car, but it happened only twice so I didn't bother checking it out. Later, on a highway, when I went about 70 or 75 mph the car vibrates. The driveshaft seems to be intact and u-joints were replaced about 1k miles ago. I jacked up the rear end and put it in drive, the vibration is still there at 70 or above mph. I didn't try going above 85 because I didn't want anything to fall out. Could it be the transmission going or drive shaft needs to be balanced? Could wheels have something to do with it?
thanks for any help.
Old Jul 3, 2007 | 10:20 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: vibrations above 70 mph
yes to all the above questions
wheel balance (most common), drive shaft, separated tire, loose steering /suspension parts are most likely suspects then brakes, internal trans internal diff, wheel bearings(although bearings,trans diff would possible make noise.
Easiest check the wheel balance then go from there
Old Jul 3, 2007 | 10:29 AM
Car: numerous
Engine: ls1, others
how could the wheel be knocked out of the balance? I think i eleminated the steering by having the driving wheels in the air and it still have vibration. Also what do you mean by seperated tire? All the tires look ok. I was driving nonstop for about 200 miles and it was fine for first 150 miles, then i heard clanking noise and last 50 miles or so i finished going 60 mph. What could've happened that knocked it out so fast without any warning?
Old Jul 3, 2007 | 11:21 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Wheel weights can come off anytime for any number of reasons. Rub a curb loosening the wheel weights up then centrifigal force throws them off for example. A separated tire is when the tread becomes unbonded to the carcass, Most cases you will see a bulge in the tire and it will feel like you are sitting in a rocking chair sideways whild at low speed 20MPH or less, but in some cases it can not be felt till highway speeds. I have seen that cause a mis fire code in an OBD 2 car before even if the tire looks ok.
As I said before start with a wheel balance. It is by far the easiest to check and most common cause of a high speed vibration.
I wasn't suggesting the steering is the problem just listing possible causes of high speed vibration.
Ed1LE
Sep 30, 2018 09:14 AM
darwinprice
17
Oct 11, 2015 11:51 PM
gt4373
Oct 8, 2015 10:37 AM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
InfinityShade
Sep 18, 2015 08:32 PM
