2.8L transmission good for anything?
Old Jul 20, 2007 | 08:47 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I have a trans off a 2.8 s10 motor. Not sure if its a 200r4 or 700. The bellhousing bolt pattern looks a little different from a small block. Is it? Is this trans good for anything?
Old Jul 20, 2007 | 10:11 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 2.8L transmission good for anything?
It will hold tarps down in your yard that cover the "good" parts!
Seriously, it is a 700R4 (if it is a 4 speed) and it will work in third gens with 4cyl or V6 engines if you switch the tailshaft housing for one of ours with the torque arm mount bolt holes. The bellhousing pattern should be flat across the top and it fits "metric" bolt pattern GM engines. Metric engines are most front wheel drive 4 and 6 cylinder engines (except the Quad4) and the V8 engines from front wheel drive cars using the Cadillace HT4100/4500 and northstar family (including Olds Aurora)
Old Jul 20, 2007 | 10:13 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Old Jul 20, 2007 | 10:32 PM
performabuilt's Avatar
The 2.8 700r4 has the same hard parts re planets etc as the V8 version so its a good source for hard parts. Everyhing is not the same but many things are. And becaue they were behind a small engine they are ussually in really good shape
Old Jul 21, 2007 | 12:00 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
So its worthless then. I dont plan on ever using a 700 in anything, so its off to ebay. Perhaps I can sell it for a dollar and someone will take it off my hands with the motor.
jhawkeye
May 25, 2022 06:33 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
BurlyChev
Aug 16, 2015 09:08 PM
milk
Aug 10, 2015 06:26 PM
