9 Bolt rear end slop
Old Aug 21, 2007 | 11:33 AM
subliminal's Avatar
I have the 9 bolt rear end in my car. The problem Im having is whenever I let off the gas and then hit it again there is a loud clunk coming from the rear of the car. I thought it was the transmission mount but I replaced it with a polyurethane one and it is still doing it.
When I had the rear of my car jacked up I noticed there was alot of slop in the rear end, I can turn one wheel about a 1/4 turn then I hear a clunk and the other wheel engages. Is that normal? Would that be what is causing the clunk when I let off the gas and get on it again or is it something else?
The only other thing I think it could be is the torque arm mount cause that is shot too. I just changed the oil and put some new posi additive in it last night and its still doing it. There were no missing or damaged teeth in the rear end that I saw, there wasnt even any small metal shavings. Could something just need readjusting in the rear end?
Old Aug 21, 2007 | 06:49 PM
subliminal's Avatar
Re: 9 Bolt rear end slop
No one knows anything about rearends on here?
Old Aug 21, 2007 | 09:31 PM
TransAM Joe's Avatar
could possibly be the u joints on the drive shaft are shot, you might try greasing then to see if there is any life left in them. If u joints are ok or replaced and still making the noise, backlash on the pinion gear could be off.
Old Aug 21, 2007 | 09:37 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
You have to tighten the pee-water out of the pinion nut. Also what about the crush washer?
Old Aug 22, 2007 | 09:09 AM
subliminal's Avatar
Its got a new drive shaft on it with new u joints. I dont know what what the pinion nut or crush washer is and where it is on the rear.
Old Aug 22, 2007 | 04:21 PM
blackblazer717's Avatar
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
well when you get a clunk on accel. and decell. that means you have alot of backlash or to much pinion depth. and tightening the pinion nut will do nothing but make it worse. its time for a rebuild my friend. carrier bearings and all. get a ring and pinion, install kit. REUSABLE crush washer (yes they make them. richmond sells them) and carrier bearings. than your clunk will go away. but before i buy anything i would check the condition of the splines on the axle shafts as well as see how much junk is at the bottom of the center section
LUKE
Old Aug 23, 2007 | 02:04 AM
subliminal's Avatar
Thanks blazer, looks like I will be replacing this rear in the not so distant future then.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
