Flywheel & T.C. bolts
Subscribe
Aug 29, 2007 | 12:14 PM
Well I thought I had ordered everything I would need to drop my motor in the car this weekend but obviously I miss a few small things. Would grade 8 bolts from the local hardware store work for my flywheel and my torque converter bolts? I had planned on getting ARP bolts but if grade 8 stuff will work then I'll save the $10 shipping charge.
Reply 0
Aug 29, 2007 | 12:32 PM
Re: Flywheel & T.C. bolts
Flywheel bolts are not found at your average hardware store. Around here both Autozone & Advance Auto carry them though. Make sure to locktite them. Does your convertor have threads as part of it, or do you need a nut and bolt?
Reply 0
Aug 29, 2007 | 01:06 PM
Don't use hardware store stuff for that.
At least, not if you've become accustomed to having feet, and you think you might want to keep them around a little while longer.
Go down to VatoZone and get the Mr Gasket ones out of their "performance" aisle.
Reply 0
Aug 29, 2007 | 02:59 PM
Are the Mr Gasket ones stronger than Grade 8 bolts?
Reply 0
Aug 29, 2007 | 04:03 PM
Strength isn't the issue, bolt design is.
Reply 0
Aug 29, 2007 | 04:59 PM
the flexplate/flywheel bolts have wider flatter heads than regular grd8 hex bolts
Reply 0
Aug 29, 2007 | 05:56 PM
Plus they are harder than any hardware store fastener - try to hacksaw a flywheel bolt into a flexplate bolt - they are fine pitch thread, and have a lockwasher of sorts. I would still use locktite though.
Reply 0
Subscribe
