lt1 style clutch slave
Old Aug 31, 2007 | 10:43 PM
spina74's Avatar
Car: 01 Trans Am Ws6, 92 Camaro Rs
Engine: 6.0, 305
Transmission: T56,700R4
Axle/Gears: 3.90 9", 2.73 10 bolt
Ok, i ruled out that my clutch slave was so pressurized that i couldn't get it to bolt on. I tried everyway to get it on, so i unfortunately had to take the hydraulic line off then put it back on. So now I had 2 bleed the line, I read on one of the post to aim the rod down and pump the slave by hand since I dont have a bleeder valve, so I did that, and refilled the reservior, and pumped it some more. I bolted the slave on and check to see if it worked and it didn't, so now I don't know what else to do with this whole bleeding thing.
Old Sep 1, 2007 | 09:15 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
Re: lt1 style clutch slave
mity vac tool can help
Old Sep 1, 2007 | 10:34 PM
spina74's Avatar
Engine: 6.0, 305
i've decided to just buy a new pre-bled slave since i cracked one of the bolt holes, so im just gonna take the safe route and get a new one.
Old Sep 4, 2007 | 04:31 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
matt, you can bleed those by pumping the pedal also if you dotn want to get fluid everywhere. gives your leg a workout also
Old Sep 4, 2007 | 09:33 PM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
How can u bleed the master cylinder like u say? do u have to take brake fluid reservoir lid off?
Old Sep 4, 2007 | 10:36 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
ive done all mine that way. you will see it start to burp air through the reservoir
guess i got tired of getting brake fluid everywhere, yeah my legs geta workout, but its a trade off
devilschariot
Feb 25, 2016 03:08 AM
L0tuS
Oct 4, 2015 08:07 AM
L0tuS
Sep 4, 2015 11:16 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
