700R4 date
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
700R4 date
I have a 700R4, that is a remanufactured unit, that I'm trying to sell. Can anyone help figure out when this thing was rebuilt?
Here is some pix:
http://members.cisdi.com/~anesthes/700R4/
The white label that says R DOT has a serial # of 1030058, on the green plate the serial # is 277 9141602, and on the edge right where the tail shaft bolts on there is a number engraved, it says 1H516483
Thanks!
-- Joe
Here is some pix:
Thanks!
-- Joe
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: 700R4 date
On the right side there is a ID number. Just above the pan lip at the opposide end as the servo cover (round) on the back right side, is a rectangular flat boss area. There should be a series of letters/numbers there. Write them down and post them up.
Car: '89 Firebird Formula
Engine: 305 TBI
Re: 700R4 date
so your really putting a T5 in that vette huh? I didnt figure many people did that to the C4's, i read about them doing it to C3s all the time though.. but they were around to get equipped with the weakest engines in all of history :P
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: 700R4 date
-- Joe
-- Joe
Re: 700R4 date
Sorry then. I cant help you on that one =( Maybe try to contact a dealership service/parts center. It is a reman unit Im sure they have installed B4. Or try to contact Hydramatic. Serial number leads to some thing.
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Re: 700R4 date
Joe,
On the drivers side of the trans, near the shifter shaft, there is a dime sized circle with the date cast into it. A small wire brush will clean it up well enough to read it easily.
I have never been able to figure out how GM codes their remanns. It is a shame they grind off the factory stamping when the attach the green tag.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
