700r4 help
Old Oct 3, 2007 | 08:19 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
700r4 help
If I get this engine and trans I planning on buying and it is broke how much to rebuild it myself??
Old Oct 4, 2007 | 12:43 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: 700r4 help
Depends on how much you intend to build it. Basic kit with clutches, seals/gaskets, filter, band, bearings, thrust bearings/washers, and other tidbits are most likely around $200. Plus add in for fluid, tools, and cleaner...etc. If there is anything broken and you have to replace hard parts, it will get more costly. There are some Hi-Po kits from a few online places that include better clutches, improved 3-4 clutch pack for more $$. Also there are some 'known' factory parts that go bad you might consider upgrading. So then your cost starts going up alot more. Having a local joe shop rebuild it carry in is around $900+ estimated. But thats a basic rebuild, no hard parts included in that price if needed, if they 'shift kit' it then its maybe a little more and nothing gets done other than a hard shifting tranny. Very few shops take the time to go over details, spend money on the good stuff, etc. And if they put a converter in the price, its a genero rebuilt converter that cost less than $100.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
