Rear End Gears
Old Oct 9, 2007 | 06:11 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Rear End Gears
Ok, I cant find any ID tags on my axle anywhere, but I have a 1991 GTA, 5.0, 700R4, with a 10 bolt posi rear. What size Ring gear did these come with and / or what part number do I need for a set of gears, preferably 3.42's or 3.73's. I don't wanna take apart the rearend just to find out, then have to put it all back together only to take it apart again when I do the gears.
Old Oct 9, 2007 | 06:37 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Rear End Gears
10-bolt for 91 has 7 5/8 dia ring gear and may have 2:73 2-series carrier. So if you want a gear chage the cover needs to come off to check what series carrier you do have.
Old Oct 9, 2007 | 07:29 PM
plumminfool's Avatar
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
Re: Rear End Gears
The RPO code will tell you if the gear hasnt been changed. or if the rpo sticker hasnt been changed. post your G codes.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
