TV cable remounting?
Old Oct 13, 2007 | 07:12 PM
Gramps's Avatar
Car: 87 Camaro IROC
how do i go about getting a bracket and cable for my 700r4 to work with a carb, i currently have a TPI, i doubt i can use the same cable and bracket, so what can i do?
gramps
Old Oct 13, 2007 | 11:51 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: TV cable remounting?
You will need a different TV Cable and Bracket. 1st off what intake and carb RU using?
Old Oct 14, 2007 | 09:53 AM
Gramps's Avatar
Car: 87 Camaro IROC
havent decided yet, prob an air gap intake but havent decided on carbs. i thought there was just a bracket and cable kit for carbs and it was "one size fits all".
Old Oct 14, 2007 | 11:07 AM
Mikz86TA's Avatar
Nope. If you were going Q-Jet and Stock Manifold, then get a stock bracket. Holley Carb you will need both a adapter for the throttle lever made by them and the mounting bracket made by them. There is also a set made for Edelbrock/AFB carbs. If you get a BG/Demon, the Holley stuff will work with some mods. I got a BG/Demon and am using a Holley throttle adapter slightly modified, and a billet bracket I got from Jegs (their brand) made to hold the throttle cable and the additional part to hold the TV cable. The starting point and the rotation degree of the TV cable play an important role in getting the TV system to work as it should
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
