ford t5 and chevy t5
Old Nov 11, 2007 | 10:12 PM
jamesw343's Avatar
Car: 1986,1988,1989 IROC
Engine: ?,L98,383 L98
Transmission: ?,700r4,700r4
Axle/Gears: ?,3.27,3.45
what is the difference between a ford t5 and a chevy t5?
Old Nov 11, 2007 | 10:46 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: ford t5 and chevy t5
input splines and shifter mount. ford's don't have the torque arm mount. plus i don't think the ford t-5's will bolt up to a chevy bell housing.
Old Nov 11, 2007 | 11:22 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The Chevy T5 is also tilted 23 degrees while the Ford T5 is straight up, thanks to the bellhousing.
Basically, the internals are similar but the outside is different.
See my sticky thread at the top about "everything we know about the T5."
Old Nov 26, 2007 | 07:25 PM
autotec101's Avatar
Car: 86 bird
Transmission: 5 spd
Is it possible to swap out the 4 forward gears and counter shaft from the ford to the Gm T5 keeping the GM 5th gear and tail shaft....Basically I have both a GM T5 and a Ford T5...I want the GM trans But would like the Ford gear ratios and 10 spline input shaft
Old Nov 27, 2007 | 01:16 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Why do you WANT a 10 spline input shaft?? I thought that was a bad thing?
Plus then you'd need to get an oddball clutch for the thing.
I think that's possible, however difficult - and again, why? The ratios are pretty close aren't they?
Old Nov 27, 2007 | 05:35 PM
autotec101's Avatar
Car: 86 bird
Transmission: 5 spd
I am doing a v6 to v8 swap I currently have a 14 spline which can only find a 9-1/8 in disk and 1st gear is 4.03 with a 10 spline I can get 10-1/4 in disk and 1st gear is 2.94
Old Nov 27, 2007 | 10:51 PM
Kevin91Z's Avatar
You should probably contact these guys:
http://www.rsgear.com/
There's another company that begins with an H in the northeast but I cant remember their name. They do a lot of Ford T5's.
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
Street Lethal
Sep 7, 2015 01:09 PM
Reborn756
Sep 4, 2015 03:42 AM
TRAXION
87
Nov 22, 2008 10:33 PM
Ward
May 18, 2001 01:06 PM
