9 bolt to 10 bolt DISC rears
Old Dec 4, 2007 | 05:32 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
I have a 9 bolt disc rear i would like to swap for a 91-92 z28 disc rear is the only thing i need to swap my 9 bolt brakes to the 10 bolt disc rear are 10 bolt disc backing plates?
Old Dec 4, 2007 | 06:25 PM
Re: 9 bolt to 10 bolt DISC rears
If your 9-bolt came with the car, it should have the same brakes (PBRs) that the 10-bolt has.
If the 9-bolt has the Saginaw :barf: brakes, you'd be shooting yourself in the shorts to take the PBRs off the 10-bolt and put that other crap in their place.
Old Dec 4, 2007 | 06:29 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
the 9 bolt has pbr brakes i just want to ditch the 9 bolt for a 10 bolt and want to keep the same brakes that are on the car.
Old Dec 4, 2007 | 07:10 PM
a1990camarors's Avatar
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
Why would u trade a stronger rear end out for a weaker one?
Old Dec 4, 2007 | 07:16 PM
Well then you don't have to change ANYTHING; you can just bolt your calipers onto the other rear. They're the same system.
Old Dec 4, 2007 | 07:18 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
because the 9 bolt can only get up to 3.70 gears and i need 4.10's for my setup. Also the only thing nicer about the 9 bolt is the bolt on axles and right now my 3.27 3 series 9 bolt posi is wearing and new ones are 800 dollers. Not worth it in my mind my 13 second car isnt going ot break the 10 bolt and it can be made stronger then the 9 bolt.
the 91-92 z28 rear is bare no backing plates or rotors just axles housing posi and gears.
Last edited by 91greenbird; Dec 4, 2007 at 07:20 PM. Reason: Automerged Doublepost
Old Dec 4, 2007 | 07:22 PM
Those details DO matter.
Yeah, well then you need the right backing plates. Not much way around that. As long as the 10-bolt has the small 4-bolt (disc) flanges, it'll all just bolt right up.
Old Dec 4, 2007 | 07:26 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
alright thanks wonder how i can get these backing plates seems like there gonna be a bitch to find.
Old Dec 4, 2007 | 07:28 PM
Try GM first.
Old Dec 4, 2007 | 07:30 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
think the dealer still carries them also could you put these brakes on a drum rear if i got the 10 bolt backing plates?
Old Dec 4, 2007 | 07:38 PM
yes i agree with sofa those details do matter lol. I thought u just wanted a 10bolt well idk lol. But now i understand and yes u can build em tough i run one in the low 12's on a z28. Dint know 9bolts only allowed 3.73s then again ive never done research on them never had one. You could try Ebmiller for backing plates he might know somthing hes on the brake board.
Old Dec 4, 2007 | 07:45 PM
Iunno... what did they say when you called them?
Not exactly; but it IS possible to mod the flange enough to graunch them on there. Or, as mentioned, ebmiller88 has had some "conversion" backing plates made, although I haven't seen one and don't know what, if anything, you have to do to use them. When you talked to him, I'm sure he was more informative than me about them.
So is this a disc 10-bolt (small 4-bolt flanges) or a drum 10-bolt (big tall flange with one large hole)?
Old Dec 4, 2007 | 07:55 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
small 4 bolts i was just curious if the drums would work. havent tried the dealer yet ill call ken dixon chevy tommarow and see.
Old Oct 26, 2008 | 09:24 AM
84'B.A.T.A.'s Avatar
Car: 88 Iroc-Z
Engine: 388 HSR
Axle/Gears: 9 Bolt 3.70
I have a disc brake 9 bolt rear out of an 88 iroc, can i swap the brakes to my 10 bolt on my 84 trans am?
Old Oct 26, 2008 | 09:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO. Not directly, if the 84 has drum brakes. You can mod the axle flanges or simply purchase a conversion kit from Ed Miller:
http://www.flynbye.com/catalog/c1_p1.html
If they're both disc brake rear ends, yes.
JamesC
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
