formula posi in a v6
Old Dec 4, 2007 | 09:33 PM
vintageisbetter's Avatar
Car: 1992 Firebird, 1953 CJ3B
Engine: 3.1
Transmission: 5speed
my friend has a dead 87 fb formula... and he will sell me the posi out of it, but my question is
will a 87 formula posi fit in a 92 firebird v6 rear end?
will the the axle spline and ring gear line up alright or will i have to take the whole axle? v6 is a 10 bolt.
Old Dec 5, 2007 | 07:13 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: formula posi in a v6
No,,,For one reason, the axle shaft spline count is different (26 for 1987) & (28 for your 1992). Unless you want to back to 26 spline axle shafts it will work (if the carriers are the same series) for 10-bolt parts are interchangeable. Gear set-up will have to be done over. Or change the whole axle assembly. This looks like a DIY job that going to over most peoples experience.
Old Dec 5, 2007 | 08:23 AM
No.
The Formula almost certainly has a 9-bolt; and the 6-cyl car has a 10-bolt.
No internal parts whatsoever interchange, under any circumstances.
Old Dec 5, 2007 | 06:23 PM
Engine: 3.1
dang... well is there anyonther way to put in a limited slip?
Old Dec 5, 2007 | 06:34 PM
Yeah, of course.
Get the right one; unbolt the one-wheel-squeel carrier, bolt in the other, check backlash. Install cover and fill with fluid. Enjoy.
Old Dec 5, 2007 | 06:56 PM
adam86's Avatar
Car: 1989 GTA
Transmission: Stock 700r4
Axle/Gears: 3.08 POSI
just change out the whole rear end... its actually pretty easy.. i've done it several times by myself..
so if you and your buddy go at it and have some tools it should be no problem
dbrochard
Jan 28, 2016 08:42 AM
Prodigious
Sep 18, 2015 05:23 AM
manifoldsrme
Sep 17, 2015 11:40 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
