Transmission Connections
Old Dec 9, 2007 | 10:59 AM
w01fm4n's Avatar
Car: 1991 Chevy Camaro RS
Engine: 305/5.0 Liter V8
Transmission: Borg-Warner T-5
Axle/Gears: Stock... Not Sure Yet
The Electrical Connections that go to the Transmissions, one is near the front of the Tranny, i'm guessing that is the VSS connection, but i found one near the rear of the tranny hanging off the tranny. my question is what is this connection, and where does it go? thx Scott
Old Dec 9, 2007 | 11:43 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Transmission Connections
I'm guessing you're talking about a T5, since that's what you list your car has.
There are only two connections. One for the reverse lights, and the other for the speedometer. They have different plugs so you cant put them in the wrong spot. The one in the back on the driver's side tailshaft is the speedometer. The other for the reverse lights is in the front but I dont remember if its on the driver's side or passenger side. On my T56 its on the passenger side.
Since you arent sure of your rear end gears, Camaro RS with a TBI engine and T5 transmission would have an open 3.08 rear end with drum brakes.
Old Dec 9, 2007 | 12:02 PM
w01fm4n's Avatar
thanks for the information. =)
GTAman
Jul 3, 2024 07:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
angel2794
Sep 8, 2015 06:22 PM
jtwoods4
Sep 3, 2015 05:39 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
