700r4
Old Dec 18, 2007 | 08:11 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
700r4
i am putting a 700r4 in my 82 sc, which i belive ad a th350 in it. what do i need to do to make this swap. do i have to move the x-member and also, do i have to shorten the driveshaft. any info will help....thanks guys
tyler
Old Dec 18, 2007 | 09:06 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 700r4
Okay, this is a good idea!
Your car would have had a TH200 3 speed from the factory, not a TH350.
You will need a newer crossmember for the TH700R4, and a 4 speed automatic shifter and shift indicator plate for up top. You should be able to re-use your driveshaft and cooler lines. You may need a new torque arm mount if yours is really beat up.
On another note, which engine do you have now? If you have a V8, you could just swap in a TH2004R trans with NO MODIFICATIONS except the shifter and shift indicator plate. Your TH200 should have a different style torque arm mount than the 700R4.
Could you take a picture of your crossmember and torque arm so that I can see what it looks like? I may want to buy it!
Old Dec 18, 2007 | 10:18 PM
lonman89's Avatar
Car: 1985 chevy camaro IROC-Z
Engine: 5.7 litre 350 4 bolt main
Transmission: 700r w/B&M shift kit
Axle/Gears: 10 bolt w/3:42 gears
Re: 700r4
thats odd because my old 82 z28 had a turbo 350 in it and i ran the numbers on the tranny to confirm it was a th350 and not th200
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
