TH350...how to tell what has/has not been done
Old Dec 23, 2007 | 08:46 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I picked up a TH350trans last fall at the Englishtown swapmeet out of an 86 Firebird.
Before you all beat on me saying this trans never came with that car, etc. etc It was a stripped out braket car with a 350 carbed motor, this trans and a spooled 10-bolt rear. Supposedly the car ran 12's. It has the B&M bracket on the side and all.
The question have is, besides tearing the entire trans apart, is there a way I can tell what has been done to the trans? Is there an easy way to tell if the pump has been up graded or not? If I take the pan off, what would I be looking for to tell me this is not s stock rebuild?
Any help would be appreciated....
This trans is going into a car that weighes 3600, revs to 7000 and has 4.56's
Should I even try putting this trans in, or just use it as a core for ATI?
Old Dec 23, 2007 | 10:11 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: TH350...how to tell what has/has not been done
Simple answer. No. Even if you tore it down, I doubt you would find anything different about it other than maybe a shift kit was installed.
Old Dec 23, 2007 | 10:49 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
So should I use a basically unknown build in a car that makes 550HP or should I use it as a core and have ATI build me one?
The only difference is that ATI charges $922 for a trans and I already have this one.
Old Dec 24, 2007 | 07:21 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
If you already own it, why not install it and run it. If it breaks, swap it out with an ATI.
If you have more money than I do, use it for a core and buy the ATI trans now.
