tv cable
Old Dec 31, 2007 | 10:47 AM
monoply6's Avatar
Car: 89 trans am gta
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
tv cable
hi all and a happy new year ok so put gear box etc back on car conected tv cable to throtal bracket have not adjusted it yet the thing is the throtal bracket is not fully closed its open about 1cm so when i adust it will it close all the way i have removed the crusie control cable would that make a difference and is it or right to make a set of cooler pipes from cooper as tring to get replacent ones over her is not easy thanks
Old Jan 1, 2008 | 12:45 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: tv cable
Once the TV cable is adjusted, everything should line up perfectly. Reason being you're adjusting where the cable goes when the throttle body is full open.
Press and hold the button while you slide the cable towards the windshield.
Let go and then reach over to the throttle body. Open the throttle up to the full open position. Should hear the TV cable click and it will stop exactly where it needs to.
The cruise control cable should make no difference whether it's installed or not.
Old Jan 1, 2008 | 09:33 AM
monoply6's Avatar
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
Re: tv cable
hey thanks all set up now id put the tv cable on the cruise control bracket daylight and no beer i can see straight now lol thanks again
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
