torque arm woes
Old Jan 4, 2008 | 06:46 AM
monoply6's Avatar
Car: 89 trans am gta
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
torque arm woes
hi all need a little advice on how best to realine my dif houseing as it at moved its pointing up about an 1nch highter at the front and can not get torque arm on. my brother and his mates removed the gear box t,arm ect for me as i put my back out they came back put every thing back in but left the back part that bolts to bif. if i jack back up and put axle stands on the tubes will doing this bring the dif in to the correct possion thanks
Old Jan 4, 2008 | 08:59 AM
Re: torque arm woes
Jack the back end of the car up until the axle hangs free, and support the car by the places at the front end of the LCAs. Make a note of how far the rear hangs. Put your jack under the "pumpkin", and jack the axle up just enough to raise it off of the extension stops of the shocks; maybe an inch or 2, no more. Undo the harware at the bottom of the shocks (one nut each side) and free them from the rear end. Lower the rear end until you can remove the springs. Remove them. Jack the rear back up to a couple of inches above where it was when it was hanging free. Support the rear end with 2 more jack stands under the axle tubes: not the shock brackets, not the rear end of the LCAs, not by any other part, except the axle tubes. Held up this way, there will be no torque whatsoever on the rear end, and you should easily be able to rotate it to where it needs to go, to get the TA back onto it.
At that point, you are exactly 2 nuts away from replacing the shocks and springs. I STRONGLY recommend that you go ahead and do that, since you'll have done about 90% of the labor. Might as well just finish it up.
Old Jan 4, 2008 | 10:41 AM
monoply6's Avatar
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
Re: torque arm woes
hi thanks for your reply thats big help
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
