700r4 partial reverse
Old Jan 14, 2008 | 07:18 PM
Litton's Avatar
Car: 91 camaro
Hi everybody, Ive got a 91' RS w/ a 305. The transmission runs strong as long as its moving forward. Reverse is where I've got issues, on level ground the transmission acts like its trying to go in reverse but just slips. I would figure its a cooked tranny, but the odd thing about it though is if a friend shoves the car back or its reversing down a hill, it will go into reverse. Its got plenty of fluid (could use a change ),no leaks, shift cable should be adjusted correctly, and I still got first gear. I'm not sure if there are any vacuum or other lines clogged or broke. Before I completely destroy the transmisison, I'm wondering if anyone had any thoughts.
Old Jan 15, 2008 | 01:15 AM
Pro Built Automatics's Avatar
Re: 700r4 partial reverse
Does the situation get any better when it is warmed up? If it is slipping as you say park where you do not make the problem worse. It does not take long to waste the reverse clutches.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
