700R4 slipping
Old Jan 19, 2008 | 02:41 AM
Pontiacguy18's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Axle/Gears: 3.42 posi
700R4 slipping
Ok so I have been having problems with my tranny for the past 6-8 months. First off it slips between 1-2 2-3 and 3-4 gears, and if that isnt bad enough its burning tranny fluid. This all happens in overdrive, in drive the tranny usually doesnt slip as much, sometimes between 2-3 but thats usually it. I am stumped and wondering if I should just rebuild the whole damn thing. Thanks for your help
Old Jan 19, 2008 | 02:49 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 700R4 slipping
Sounds like it's definitely time for a rebuild.
Old Feb 2, 2008 | 02:20 PM
1991Camaroz28's Avatar
Car: 91 Z28
Transmission: TH700-R4
Re: 700R4 slipping
the 700r4 runs too hot for it's own good. when you rebuild the trans get yourself a good after market trans cooler to protect your investment. i run a B&M that was small and easy to install.
Old Feb 2, 2008 | 06:11 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: 700R4 slipping
Mine was doing similar things. I ditched it and installed a T56 . That doesnt help i know, but usually the 700 has some weak points, and you can diagnose the problem with the symptoms.
2-3 shift slippage can be blamed on the 3-4 clutch pack, which is the most common. The rest of the stuff you described is other things. You should definately rebuild it, or if i were you, i would buy a used one that isnt slipping and put a shiftkit in it. With a 305, you dont need to build it to race specs, you can get away with a good tranny, and the moderate upgrades, like shift-kit, new torque converter, with a slightly higher stall, corvette servo, and a tranny cooler.
jrdturbo
Mar 31, 2016 02:58 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
