700R4 to 4L60E?
Old Feb 2, 2008 | 01:39 PM
drivera's Avatar
Car: Chevy IROC - Z 86'
Engine: 5.7 TPI
700R4 to 4L60E?
I've recenlty swapped a 5.7 into my 86 IROC and I now need a tranny for it. I was wondering if i should get a strong 700r4, or could i convert to a 4L60E. I was wondering if they make converison kits from 700r4 to 4l60E? Thanks.
Old Feb 2, 2008 | 05:16 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
Re: 700R4 to 4L60E?
Yep, they do. There's a computer you need to get to control the 4L60E. It cost about $700 last time I checked.
I'm not sure why it would make sense though. For all that money you get the exact same trans but the ability to control exactly when it shifts. I debated doing that, but put the money into a better 700R4 and a high stall.
Old Feb 2, 2008 | 05:33 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: 700R4 to 4L60E?
How much torque do you plan on eventually putting through your drivetrain. I did NOT pay enough attention to the different 'stages' of the trans buildups and my naivity got taken avantage of by a trans shop that had a great reputation. If you think you're going to go over 400 lb torque, you might want to look into steping up to the 4L80E. That should be the last automatic overdrive you'll ever need. Plus, one of the major performance manufactures, just designed a new gearing that gives a better launch and adds 35% more overdrive (makes for better fuel economy or usefulness of 3.7ish rear end gears) Nitro
Old Feb 3, 2008 | 10:07 AM
drivera's Avatar
Engine: 5.7 TPI
Re: 700R4 to 4L60E?
I plan to put out about 350+ torque.
I plan to put out about 350+ torque. but no more than 400.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
