Aftermarket 9" rear & Brakes
Car: 88 Chevy Camaro IROC-Z
Engine: L98 5.7L 350 MAF TPI
Transmission: TH700R4
Axle/Gears: BW 9bolt/3.27 gears
Okay, Been doing searches for this dilema for weeks now. Hope I have the right board for this. If it's been repeated, which I cannot find in searches I apologize.
I'm looking to buy an aftermarket 9" rear, Currie, Moser ETC.
I'm also looking to upgrade entire brake system front and rear that will fit under my stock 16x8 rims.
Does anyone know of a brake system that will fit front and rear, Baer Etc., and what housing adapters are required for the 9" rears when order is placed.
Money will not be an option.
Looking to keep everything uniform.
Suspension and everything is stock.Currently have BW 9bolt with iron calipers.
My head is spinning, would appreciate any suggestions.
Re: Aftermarket 9" rear & Brakes
Easiest thing to do is to get your 9" set up from the factory for the Explorer rear discs. You can drill the GM wheel pattern into the rotors.
Ask whoever you get to build your rear what they have available; I'm sure tha twill be one of the options. They may even suggest it.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
IIRC the 4th gen discs will work fine on the rear, you can order it drilled for them, and you can get the front upgrade from ebmiller or other places
I wasn't sure, but I thought 4th Gens would work. I thinking about LS1's for front and back. I looked at mosers site and they have 10/12 bolt housing ends that they can assemble a 9" rear with. Now i just have to locate all the parts for the brakes.
Thanks!
Thanks!
Eric-86sc
Apr 3, 2016 03:52 PM
