How do i know which diff i have?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: How do i know which diff i have?
How the car was originally equipped and what's in it now are sometimes very different things. Years may have passed since the fluid in the diff was changed. Take this opportunity to do that and to verify your set-up:
Here's how to determine the ratio (jerk the diff cover and look): Numbers are stamped on the ring and pinion:
41 : 15 = 2.73
41 : 14 = 2.93
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
JamesC
41 : 15 = 2.73
41 : 14 = 2.93
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
JamesC
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
An 88 GTA 5.7L would have come with either a 2.77 9-bolt rear end, or a 3.27 9-bolt rear end. What RPM are you at in drive (not 4th gear) on the freeway?
