need help choosing a rear end
Old Feb 17, 2008 | 05:08 AM
hotrod78's Avatar
Car: 1986 Trans-Am
Engine: chevy 350
Transmission: TH350
I have a 1986 Trans - Am with a 1975 chevy 350 with the TH350 Trans.Which rear -end do you guys recommend.Thanks
Old Feb 17, 2008 | 05:20 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: need help choosing a rear end
If you have a decent budget - like a couple thousand dollars - I recommend the Moser or Strange aftermarket axle assemblies. You pick, ford 9 inch or chevy 12 bolt, depending on what you like best. I personally like the Dana 60 that those guys make for our cars, but some people don't like the weight. I like the unsprung weight that it adds and you certainly don't ever have to worry about rear end failure again!
If you are on a budget, which your engine/trans combo seems to suggest, then keep trolling the classifieds and eBay for a third gen Dana 44. They were sold as a service replacement from the factory so they are a direct bolt in. I just found a 3.54 geared unit outside of Miami for under 400 bucks on eBay a few weeks ago so don't give up hope.
That's my two cents and I'm sure that others will chime in later after Church gets out this morning!
Old Feb 17, 2008 | 06:11 PM
hotrod78's Avatar
Car: 1986 Trans-Am
Engine: chevy 350
Transmission: TH350
thanks, I was thinking about a 9 bolt rear end are these any good
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
