torque arm bracket
Old Feb 27, 2008 | 04:35 PM
kaitlin's Avatar
Car: 92 rs conv
Engine: 3.1
Transmission: a4
Axle/Gears: 3:42
torque arm bracket
just swapped auto to manuel and the bracket for the manuel has the lips facing in can i just swap the auto bushing being it faces the correct way for the torque arm
Old Feb 27, 2008 | 05:55 PM
phillip_helmet's Avatar
Car: '84 Camaro
Engine: 5.3l TSP 224r
Transmission: TH350 3600 stall
Axle/Gears: LS1 3.23
Re: torque arm bracket
Nope, sure can't. You'll have to get a torque arm bracket for a T5. If you can't find one used that has the lips facing the right way, just drill out the rivets and get a poly bushing that has the right lips.
Old Feb 27, 2008 | 06:03 PM
kaitlin's Avatar
Car: 92 rs conv
Engine: 3.1
Transmission: a4
Axle/Gears: 3:42
i have both brackets why cant i just drill out the bushings and swap just bushings
Old Feb 27, 2008 | 06:07 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If the bushing itself looks otherwise the same (I dont know for sure anymore, never looked at them both side by side) then I don't see why you couldn't just swap the rubber bushings over?
Old Feb 27, 2008 | 06:27 PM
Car: '84 Camaro
I'm pretty sure the actual brackets are different between 700r4 and t5. The rubber bushing may be the same, but the bracket won't bolt up to the tailhousing.
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Ragtop Man
Sep 12, 2015 12:23 AM
WickedBowtie
Sep 11, 2015 11:24 PM
Nick McCardle
Sep 10, 2015 08:36 PM
