rear disc questions
Old Apr 11, 2008 | 12:07 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
rear disc questions
I am going to pick up a disc rear end this weekend. I have a few questions.
1. IIRC disc rears only came with 16" rims. Will a 15" or 14" still fit over them? My dailys are 16". But I have some 14" tires. Would also like to try my hand at drifting some day and would like to run 15" if possible during that time.
2. I am going to assume my inflate-a-spare will still fit due to thats what rear disc cars came with.
3. The rear is from a 92 model. I have an 88 style drum ebrake(even though its in a 91). Will the cables from the 92 fit in the 88 style front section. Or will I need to make a part to get this to work. I prefure having the adjustabilty of the early style.
4. Any glitches, problems, advise to do before install items? It already has the gears I want and posi.
Old Apr 11, 2008 | 04:26 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: rear disc questions
well afaik the 15" rim will fit without issue. There are people using the 98+ 12 inch disks with massive calipers (compared to the pbrs) and running with 15" rims, so I am sure that the 11.65" disks will make it. The 14's might be a push You might have to grind down the caliper in some places not sure about that.
Old Apr 13, 2008 | 01:15 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
Yes, 15" rims fit. I have a Z28 with 4 wheel disc breaks and the factory 15" rims.
Old Apr 14, 2008 | 12:01 PM
Dale's Avatar
Engine: 350 S-TPI
Thanks. Picked up the axle yesterday. I'll try to fit some 14" on it and see. If nothing else, I should beable to pick up some 15" s10 wheels or something that will work.
Old Apr 14, 2008 | 07:49 PM
Dale's Avatar
Engine: 350 S-TPI
by measuring, I dont think 14" is gonna fit.
Next question. What are them black round things hanging from the calipers. Does it matter that the rubber inside is dry rotted and they are not sitting "square"?
Sorry, rear disc is all new to me.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
redmaroz
Aug 16, 2015 11:40 PM
