major transmission issue
Old Apr 22, 2008 | 10:51 PM
smokethevilpipe's Avatar
Ok so my clutch wasnt grabbing anymore a while back.
I came to find out that the moron that worked on this car before i bought it in december managed to put the rear main seal in completely backwards, causing a bit of a leak, thus fouling the clutch. I just finished yesterday with putting the clutch tranny and everything back in, when i go to start it, it starts fine, but i can go into every gear smoothly without ever pressing the clutch. I also notice now that my front main seal on the tranny is leaking.
Could that oil be making the clutch not grab??
Could my input shaft be shot??
HELP!
Old Apr 22, 2008 | 11:00 PM
Re: major transmission issue
wow im a tool bag, i forgot the tech specs here
Stock 1985 z28 5.0 ( WITH ANALOG CLOCK YESS)
t5 transmission
Old Apr 23, 2008 | 01:13 PM
anybody?
Old Apr 23, 2008 | 11:00 PM
no one else has had this happen?
Old Apr 24, 2008 | 08:18 PM
ok well i pulled the tranny again today
when i have it sitting in my garage, i can turn the input shaft and hold the output shaft still, is that normal??
i would assume that it is not but i am unsure, anyone know?
Old Apr 24, 2008 | 11:03 PM
85LT4Z28's Avatar
Car: 85 z28 and a 97 ford ranger
Engine: 305 carb and a 4cyl pos
Transmission: both have a 5spd
is it in neutral cause in neutral it wont spin if memory serves corect in first gear you should have movement...
Old Apr 25, 2008 | 12:09 PM
well it was doing it in neutral...
but when i shifted it to first gear or reverse, it does the exact same thing
In the car, i can go into every single gear smoothly without ever touching the clutch pedal
with the tranny out of the car i can spin the input shaft with it in gear and stop the output shaft with my hand.
Old Apr 25, 2008 | 01:36 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Are you sure it is all the way in gear. Try turning the input shaft while shifting it into gear to make sure it's in all the way. With in in any gear, when you turn the input shaft the output shaft should also turn. The output shaft will turn at a different rate unless you are in 4th gear. You should not be able to turn the input shaft and hold the output shaft from turning. Sounds like you have a bad transmission.
deracer
Apr 11, 2016 12:04 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
NBrehm
Aug 25, 2015 11:49 PM
stalkier
Aug 21, 2015 01:54 AM
mizz0313
Aug 12, 2015 06:45 AM
