Gear Removal
Old Apr 30, 2008 | 05:51 PM
jakesTA87's Avatar
Car: 87 Trans Am
Engine: 350(5.7L)
Transmission: WC T5
Axle/Gears: Junk 2.73s
Gear Removal
Can someone please tell me how to get the gears out of a 10 bolt rear end. The entire rear end has been removed from the car. I want to swap my 2.73s for the 3.08s
Old Apr 30, 2008 | 06:04 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Gear Removal
Another gear swap by the unknoning, thinking it is a DIY job. Someone else explain the facts of this little project.
Old Apr 30, 2008 | 06:07 PM
jakesTA87's Avatar
Car: 87 Trans Am
Engine: 350(5.7L)
Transmission: WC T5
Re: Gear Removal
sorry...i have never done it before...if i dont ask, ill never know ...and yes i did do a search on here and found nothing
Old Apr 30, 2008 | 08:40 PM
jakesTA87's Avatar
Car: 87 Trans Am
Engine: 350(5.7L)
Transmission: WC T5
Re: Gear Removal
anyone???...
Old May 1, 2008 | 03:44 AM
lewandom's Avatar
Car: 84 Z-28 Camaro, 2022 Chevy 2500
Engine: 383
Re: Gear Removal
what he's getting at is it's not a DIY job, it requires some special equptment (bearing press, dial gauge), and if it's not done right the rear will make noise and wear out quickly, because the shims have to be just right, on the pinion and on either side of the carrier, you could try to do it yourself, but most likely you wouln't like the results, and have to get it re-done, also, why are you going w/ 3.08 gears, 3.23 or 3.42 gears are better for street use, and 3.73 gears are good for street/strip use, especially W/ a 350, also when you do the change make sure you change out the speedo gears to compansate for the new rear gears
Old May 3, 2008 | 10:25 PM
Pat Hall's Avatar
Re: Gear Removal
Lewandom has a valid point. It's really not even worth the trouble to swap from 2.73 to 3.08. You probably won't notice much difference between the two. 3.23 or 3.42 would be more worth it. I went from 2.73 to 3.42 in my car, and the difference in takeoff power was amazing.
specialized
Jun 18, 2022 09:26 AM
junkcltr
Aug 2, 2019 11:12 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
