Mystery gearing question...
Old May 20, 2008 | 04:46 AM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
Before my gears went out i could get 1st gear to 40 at 5500rpms, 2nd to 60.. cruising i was at 2000ish at 60 in 5th. I also noticed that at 80 in 5th i was at 3000 rpms... 255/50/16 tires... The guy i bought the car off of said the differential had never been opened. I also checked the ring gear after they broke and it still had the BW on it. I dont remember the teeth count and its in the shop getting 3.73's put in so i cant check. It's an 89 formula, 305, T5, g92, n10, ws6.... wut is the gearing? it doesnt seem to match up with the 3.45 that my research has told me...
P.S. Speedometer was correct i know because of an 86mph ticket...
Tachometer isnt off as I also checked with a seperate tach when getting it timed.
Old May 20, 2008 | 08:07 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Mystery gearing question...
Is it a 9" or 10-bolt? It might not be a 3.45, it might be lower or higher. Without the P/N of the ring gear the only way to know for sure is to count the teeth.
Old May 20, 2008 | 09:53 PM
Stevo's Avatar
Car: Pair of 92 Z28s
9 bolts had 3.70s right? cause 3k rpm at 80 is not 3.45s gotta be higher then that. There are calculators that you can figure it out but i can't find one right now.
9 bolts could be had with 3.45s and 3.70s.
10 bolts had a 3.45 and a 3.73.
All 5 speed cars had at least a 3.4x so im gonna assume based on your rpm that you have 3.70s if its a 9 bolt and 3.73s if its a 10 bolt.
Old May 20, 2008 | 10:16 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
4th gear, 70 mph, what is your RPM?
Old May 21, 2008 | 01:10 AM
Nater36's Avatar
its a 9 bolt. also that was a great questoin about 4th gear at 70, 1.0 ratio right? I wish i knew but i dont I guess ill just have to wait til its outta the shop to count the teeth, could be a few weeks tho ...
I tried but im not even sure wut my transmission ratios are..
db057
Apr 28, 2019 07:45 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
