Soft shift when warm
Old May 31, 2008 | 03:39 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
I am STILL having transmission problems.
I have the transgo kit with the .500 boost valve and the 'vette servo.
When the car is colt it will chirp the tires shifting into second. When the transmission warms, the shift takes forever and is very very soft.
Any suggestions?
Old Jun 2, 2008 | 01:54 AM
Toehead's Avatar
Re: Soft shift when warm
Bump
Old Jun 4, 2008 | 07:01 PM
Toehead's Avatar
Bump
Old Jun 4, 2008 | 09:05 PM
performabuilt's Avatar
I would be suspect of internal leakage or sticking pump slide or regulator when warm
Old Jun 4, 2008 | 11:07 PM
Toehead's Avatar
I forgot to mention that only the 1-2 shift is affected, if that matters.
I will look into your suggestions... I also suspect some sort of leakage.
Thank you very much for your reply, I really could use the help lol.
Old Jun 4, 2008 | 11:39 PM
If the 1-2 shift is the only on affected I would closely inspect the 1-2 servo rings first
Old Jun 5, 2008 | 01:10 AM
Toehead's Avatar
I just put in a corvette servo. I remember installing a 2nd apply piston, is that what are you referring too?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
thejimsterz28
Sep 30, 2015 08:52 PM
mfp189
Sep 27, 2015 09:25 AM
