REAR END SHOPPING for my ZZ4
Car: 1987 Trans Am
Engine: zz4 350
Axle/Gears: 2:73
Hey whats up guys. So its that time, theres a new crate motor, (turn key zz4 350) and a street fighter 700 r4 tranny in the car and the 2.73 gears just aren't cutting it. I was hoping to put in a new rear with 3:23 or 3:42 gears in (i thought about 3:73 but i drive on the highway a fair amount) and i was wondering if anyone had any suggestions as to wear to look. I learned the hard way that when you start building up a project car money seems to just disappear out of your wallet but if possible i'd like to save a few bucks doing my rear. I was looking at complete moser rear ends and they seemed to be a fortune. Does anyone have any suggestions as to wear else i could look or any options i might have? Thanks guys, I really appreciate it.
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: REAR END SHOPPING for my ZZ4
Is this mainly a daily driven car? If so just find a used 9 or 10 bolt with a better gear ratio. Upgraded rear ends are for hard launches on slicks at the track.
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Just get you a 3.23 or 3.42 "thick" ring & pinion set for your 10-bolt's Series II carrier. It will be your best bang for the buck. And don't forget to swap the speedo gears. You'll be about 10-12 mph. off if you go all the way to 3.42.
Car: 1987 Trans Am
Engine: zz4 350
Axle/Gears: 2:73
It's an open diff and a daily driver though i plan to take it down to the track a few times.
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
is that why some people say they get away with ten bolts so long? If i DD and mess around a but my 10 bolt beefed up can handle it?
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
