Toasted my trans
Old Jun 8, 2008 | 12:37 AM
84z350crate's Avatar
Car: 84 Z28
Toasted my trans
So, the title speaks for itself. During my first pass down the local strip my transmission started to slip in third gear and that was it. I drove home goin 15mph cause anything above that it would just slip and rpm's would just jump up like I was in neutral.
Anyway the trans was a 700r4 that was just recently rebuilt less than 3k ago. I'm going to try to get it repaired under warranty, then I would like to remove that trans and get a 350 turbo trans. My car is an 84 and I have removed the electronics and have a 30spline
My question is what do I need to put a th-350 in?
What size tailshaft do I need also?
Also, can I get a non lockup trans since my converter no longer locks up because I removed the cc carb and distributor?
Old Jun 8, 2008 | 01:23 PM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
Re: Toasted my trans
i think you will need this
http://www.spohn.net/?action=product&pid=1176
Old Jun 8, 2008 | 04:32 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
I am doing the same thing to my car but mines a 4 speed manual.
I've heard if you get a TH350 with a 9" tailshaft your 700-r4 driveshaft will work, you'll need a new crossmember like the one in the last post, and you'll need a way to mount the torque arm I am using a this one http://store.summitracing.com/egnsea...5&autoview=sku or there is one that lets you reuse you 700-r4 tailshaft but I can't remember who makes it when I find out I let you know.
Old Jun 9, 2008 | 02:41 AM
Car: 84 Z28
ok thanks
Old Jun 10, 2008 | 01:31 AM
Car: 84 Z28
it turns out the dealer isn't helpin me at all with this warranty. They said because I had a shift kit in it, but they installed it. Oh man. I will definitely be doing this th350 swap.
chazman
Aug 28, 2018 03:25 PM
Scamo-2.8
May 20, 2016 07:01 PM
someone972
Aug 30, 2015 12:52 AM
chazman
Aug 22, 2015 02:01 PM
Hello, Michael
Aug 20, 2015 03:19 PM
