Advice on junkyard gears...
Old Jun 8, 2008 | 10:39 AM
Teddy Z's Avatar
My rear end started whining last year and I've decided now is the time to fix it. So I went to my local pick n pull yesterday hoping to find a whole axle, but as usual the very few 3rd gens they had there were completely stripped. I did a search around and there are numerous S10s, 1 set of 3:73 and several 3:42s. I'm thinking a used set sounds good but having never done this I have some concerns.
So my plan is to remove the carrier and label the left/right shims as they come out. I've also heard to mark the pinion nut and threads so you can retighten to the proper preload. Is there any other things I should know? Any advice on visually inspecting the gears (other than obvious damage)?
Thanks, I'd appreciate any advice!
Old Jun 8, 2008 | 03:32 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: Advice on junkyard gears...
it might work. Every case is different from the next. Just because they are mass produced doesnt mean they are the same.
armybyrd
Sep 28, 2023 12:16 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
jaridjohn
Oct 5, 2015 07:01 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
Damon
Sep 26, 2015 04:29 PM
