5 speed conversion
Old Jun 13, 2008 | 08:47 PM
camaro8811's Avatar
5 speed conversion
i am looking to first put a T5 transmission in my car. i wanted to know if there is anything that i am forgetting i need. obviously there is the trans, clutch and brake, shifter, master cylinder, and slave cylinder. i plan on getting used so i need to know if i am forgetting something. obviously i know all the mounting hardware and brackets as well.
after that, comes the 3.73's but one step at a time
Old Jun 13, 2008 | 10:42 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: 5 speed conversion
Here's a how to write up with pics and a parts list:
http://www.austinthirdgen.org/index.php?pid=14
Old Jun 14, 2008 | 07:02 AM
camaro8811's Avatar
thanks
Old Jun 17, 2008 | 10:39 AM
camaro8811's Avatar
is it true that i shouldn't put a v6 t5 in my car?
Old Jun 17, 2008 | 11:19 AM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Yes, do not put a v6 t5 in a v8 car, it wont bolt up.
I have a v8 wc t5 im selling... Everything you will need minus the pedals and the interior trim.
pm me if interested.
Old Jun 17, 2008 | 11:31 AM
camaro8811's Avatar
i would but i know shipping will kill me. i wouldn't be willing to spend more than 350 shipped. i can find them on craigslist for that kind of money locally.
Old Jun 17, 2008 | 01:12 PM
camaro8811's Avatar
also, can i use my factory computer? can i just replace the factory chip. i was going to get an aftermarket chip from tbichips for a manual. can i do this, or do i need a whole new computer?
Old Jun 17, 2008 | 03:55 PM
BCdawg57's Avatar
you should be able to just get a new PROM for your computer. The tbichips would work for you.
Old Jun 26, 2008 | 01:12 PM
camaro8811's Avatar
i have found a good deal. i talked the guy down to 375 from 600 by letting him keep 2 flywheels. the only thing is he doesn't have bolts (found them on ebay for 25 bucks) or the clutch safety connector switch. is this connector thing important? doesn't it disable the car from starting without the clutch in all the way? if it is important, where can i get one? i haven't seen them on ebay.
http://providence.craigslist.org/pts/699203353.html
Old Jun 26, 2008 | 01:47 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
it's only important if you dont want the car to start without the clutch fully depressed, when I did my conversion I never got around to hooking the saftey switch up, I just had the wires connected so it would start regardless of clutch position.
Old Jun 26, 2008 | 01:49 PM
camaro8811's Avatar
i don't know much, why is this important?
Old Jun 26, 2008 | 09:29 PM
FYRCHKN's Avatar
Engine: LT-1
Same here. I bought the switch, but I never got around to hooking it up. Just be careful about it being in gear when you go to start it. After the swap it took me a couple of weeks to get out of the habit of hop in and turn the key like when the car was an auto.... Luckily, there was never anything in front of the car whenever it lunged forward.
There's a bolt list on the page that I posted the link to. I picked all of mine up from Home Depot.
LittleFranks
Oct 7, 2015 11:26 PM
adelane
Sep 9, 2015 08:51 PM
Eric-86sc
Sep 7, 2015 02:10 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
