92 RS with 305/5 spd
Old Jun 18, 2008 | 11:21 AM
MN305TBI's Avatar
Car: 92 RS
Transmission: 5 stick gears
Axle/Gears: stock???
What rear end came stock on these? What is the specs on the gears? Should I upgrade it if it works good?
Old Jun 18, 2008 | 11:44 AM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Re: 92 RS with 305/5 spd
GM 10 bolt
The are several different gear sets that came with these cars. Check the RPO codes in the console or pull the cover on the rear end to know for sure.
Run it until it breaks unless you are adding a lot more power and you know it will fail.
Old Jun 18, 2008 | 04:19 PM
DM91RS's Avatar
Car: 91 RS
Any gear ratio above what you have now will feel better as you drive. I went from 3.08 to 3.73 and it was awesome. If you need to drive highway more than local I would recommend a 3.23 or 3.42.
Old Jun 18, 2008 | 04:26 PM
MN305TBI's Avatar
Car: 92 RS
Its pretty rough, I need to pull the back cover off and look at the ratio, just to be positive of what I have.
Old Jun 18, 2008 | 05:01 PM
DM91RS's Avatar
Car: 91 RS
I guess it does sux after driving 'up north". In the southern states you can take things apart years later and it's just road grime. If stock it will be 3.08.
DM
Old Jun 18, 2008 | 06:43 PM
MN305TBI's Avatar
Car: 92 RS
got the car in jersey this spring, no rust no grime overall clean car....off topic though, thanks for the gear ratio info....
Old Jun 18, 2008 | 07:56 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
If you plan on doing a rear swap,3.23s are great for city and highway driving.
Hawk312
Aug 22, 2017 08:55 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Trevor Tarry
Sep 15, 2015 02:04 AM
Dquickshift
Aug 12, 2015 06:21 PM
