clutch adjustment?
Old Jun 28, 2008 | 12:10 AM
lunchbox6974's Avatar
clutch adjustment?
hey i think my clutch need to be adjusted. i have to push the pedal all the way to the floor. can someone please direct me on how to tighten it up so i do not have to stomp the clutch to the floor every time i need to shift? also whenever i put the car in reverse it grinds a little. i have heard this is normal but is there anyway to stop it? i do go "1st then reverse" but it still grinds.
james
Old Jun 28, 2008 | 12:20 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: clutch adjustment?
what year car we talking about?
Old Jun 28, 2008 | 01:17 AM
its and 84 camaro z28
Old Jun 28, 2008 | 07:15 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
first thing i would check is the clutch stud/pivot ball . its the pivot point for the clutch arm . its on the drivers side of the bellhousing where the tranny mates to bellhousing . i had the same problem , my bolt had backed out . takes a 3/8 allen wrench , clearence is tight but doable . reseat stud with locktite . worked for me . hope this helps . good luck .
Old Jun 28, 2008 | 07:28 AM
tom which problem would that fix?
Old Jun 28, 2008 | 07:49 AM
UNCLE TOM's Avatar
all of them .
devilschariot
Feb 25, 2016 03:08 AM
Drone358
Dec 10, 2015 08:16 PM
camaro1185
Oct 26, 2015 06:51 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
