Rebuild or New
Old Sep 18, 2000 | 08:06 AM
StormyNight's Avatar
Rebuild or New
Ok my tranny went out on my 90 Formula. It is an auto, my question is to rebuild or buy new. And if buy new what has had the best success.
90 Formula K&N, Hypertech, Flowmaster, TB spacer
Old Sep 18, 2000 | 12:27 PM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
Depending on what you want in terms of performance, I would rebuild it and add some "goodies" to it! For example: A corvette Servo, a TV boost valve 0.500" for the pump, Raybestos-Red devil clutches....
Try and find a good transmission shop in your area and tell them what you plan to do.
Basically, a 700R4 from companies like JET and others are all basically the same. You can add the same performance parts to your original 700R4 and make it like the others for cheaper.
I just rebuilt my 700R4 this summer and I added parts that I mentioned and it works great. If you want more info, let me know.
Neil 383 IROC-Z: TFS heads/JE pistons 10.8:1/ 24lb/hr SVO inj./ Edelbrock Runners&Base/ Strange 12Bolt Diff./ Neil's Home-Built BulletProof 700R4+Vigilante 2800 stall converter & much more.........
Old Sep 18, 2000 | 03:35 PM
Pro Built Automatics's Avatar
If you want to build it yourself, then I carry everything needed to build a Hi-Performance 700R4. If you want to purchase one outright I can help there to. I am a distributor for Continental & Precision Industries torque converters. I have been building Hi-Perf transmissions going on 24 years & have built quite a few 700R4's for members of third gen. Give me a call at 800 7763288 Mon-Sat 10-6 PST
Glad Too Help!!!
Old Sep 18, 2000 | 04:31 PM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Pro Built Automatics,
What do you have in the way of hard parts for the 700R4? Do you have any beefier than stock hard parts, like the sun shell? Let me know, because I plan on building another 700 as a back-up. Thanks
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
