700-R4 and 4L60e question
Old Sep 18, 2000 | 10:10 AM
GH6801's Avatar
Im looking for a stall for my 700-R4. I heard the stalls put in IROC and Impala transmissions would fit in a 700-R4. Is this true? And if so would it be better to run this stall or buy say a B&M one?
Old Sep 18, 2000 | 12:13 PM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
More than likely the Converter you are talking about will work. The stall you are talking about refers to the stall speed of the converter. Aftermarket torque converters can be purchased at various stall speeds (i.e., 2800 r.p.m.) specific for your engine,cam setup. But make sure that the bolt holes on the converter line up with the holes on your flexplate/flywheel.
Neil 383 IROC-Z: TFS heads/JE pistons 10.8:1/ 24lb/hr SVO inj./ Edelbrock Runners&Base/ Strange 12Bolt Diff./ Neil's Home-Built BulletProof 700R4+Vigilante 2800 stall converter & much more.........
Old Sep 20, 2000 | 07:02 AM
nickd's Avatar
If I am not mistaken, you can not use a converter from a 4L60E on a 700R4 or vice versa. I believe the no. of splines are different.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
C409
Sep 1, 2015 03:42 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
