T-56 and 383
Old Oct 4, 2000 | 01:18 AM
AmorgetRS's Avatar
T-56 and 383
Don't know if this it the right place to past this, so feel free moderators to move it. Anyway, can you make a 383 and a T-56 combo work? I heard there was some problem with the flywheel not working...
Thanks,
Douglas
Cruisin' in his Camaro he sees Homies as he pass, but if he looks twice they'll try an race is lilly ***!!
Member: "This Close to my Dream GTA" club
Old Oct 4, 2000 | 10:37 AM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Sure you can make it work, if your using an 87-up block, just use the LT-1 FLYWHEEL and have it balanced to whichever your preference is, either internally or externally. If your using a pre-86 block, use a CENTERFORCE 2-piece Rear Main Seal T-56 FLYWHEEL and have that balanced to the rotating assembly of that 383 in either externally or internally. The centerforce flywheel costs around $300. This application has been done many times by people here and also on the LT-1 sites. HTHs
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
