Rearend/Torque Arm and VIN#
I have a 1986 Camaro that had a V6 in it.
The VIN is 1G1FP87S5GL103203 When I look in
my Chiltons manual under the VIN it says my car came with a V8. Ok, so maybe someone took out the V8 and put in a V6 for whatever insane reason. Or am I reading this wrong?
And I was wondering what Rearend I have and there are no numbers anywhere accept on the bottom of the front housing. And those are
22622878
K8 6-23
GM N
Can anyone tell me what those mean?
I'm putting a V8 in it and don't want a lame rearend. I'm also gonna put a TH350 in it since the tranny on the V6 won't work. And I was gonna make a torque arm bracket and bolt it up solid and make a solid tranny cross member. Anyone know if this will work or will I end up breaking something?
Thanks.
22622878
K8 6-23
GM N
Thanks.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
None of those number mean anything to me. You need to get the axle code from the right hand axle tube on the front side. It should be somthing like "2HH C 218 D"
From the serial number, the original engine was a 2.8 V6. (eighth digit is S = 2.8 V6) The standard axle ratio for that engine in 86 was 3.42 with manual or automatic transmissions.
If the RPO listing is still in the car, you can get even more information from it. G80 is posi, etc.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Best 60 foot: 1.662
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
