Rebuilding rear-end
Old Oct 4, 2000 | 04:37 PM
jax89rs's Avatar
Rebuilding rear-end
I am going to be rebuilding the rear-end in my 89 RS. It is a 10-bolt rear. Can anyone tell me the spline teeth and ring gear size?
Thanks,
Jax89RS
Old Oct 4, 2000 | 07:12 PM
ede's Avatar
ede
you should have 28 spline axles and 7 1/2" ring gear.
-=ICON MOTORSPORTS=-
Old Oct 4, 2000 | 08:08 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You might want to double check the spline count. I thought 89 was the changover year. You may still have 26 spline. The ring gear is actually 7 5/8" but it's still called 7 1/2"
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Old Oct 5, 2000 | 08:40 PM
88 GTA's Avatar
Actually, 1988 was the change over year, so you should have the 28 spline.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
